Power Products H81/ah82 hop up
Scott Grundfor
Vintage Karting items owned: 1960 homelite spitfire
1960 go kart 400c
1960 percival
Post by Scott Grundfor » Mon Feb 13, 2012 5:23 pm
Does anyone have rings for a PP h81. Mine is a converted chainsaw motor with the thicker rings. It is standard bore of 2.5" same as AH82. Rings are .059 thick. Also, would be interested in thin ring piston and rings. Who is the Power Products go to person?
I also need advice on cylinder to case gasket. I have three different thickness gaskets. Can I use a thin gasket and up the compression so long as nothing hits? Will it have a noticeable effect on piston timing? I am putting a "Dicks" Pyramid reed manifold and scalloping the piston top. Isn't it amazing how every one and his brother were making speed equipment for the early go kart engines. I love it.....
Re: Power Products H81/ah82 hop up
Post by Rob Voska » Mon Feb 13, 2012 5:58 pm
Look under "Parts & Resourses at the top of the this forum. Bobby Muha has what you need for your PP. As far as gaskets you always need to check the clearance between the head & piston. I use soft solder, turn the motor over by hand & measure it.
Scott Grundfor
1960 go kart 400c
1960 percival
Post by Scott Grundfor » Mon Feb 13, 2012 6:17 pm
Thanks Rob,
Post by ted johnson » Mon Feb 13, 2012 6:22 pm
Hank (Henry) Rotroff. He's a prince of a fellow, and his PP-82's run like rockets. He's a REAR member, so PM him. Ted
