Maico/Engray 175cc Kart engine
Scott Grundfor
Vintage Karting items owned: 1960 homelite spitfire
1960 go kart 400c
1960 percival
Post by Scott Grundfor » Mon Dec 12, 2011 11:09 pm
Hi All,
Does anyone know how many degrees BTDC this engine should be set? It supposedly has 11 to 1 compression. I will try to download ad showing engine. I think it is about 26 degrees BTDC. It is a piston port induction. I stuck (melted a corner of the piston top) a piston last time out and don't want to do that again. Where can I get a standard piston and rings for it. Also, any ideas on gearing? It has 12 X 4:00 X 5 Carlisles on the rear. Lots of torque but not too much top end.
(302.03 KiB) Not downloaded yet
Re: Maico/Engray 175cc Kart engine
Post by Rob Voska » Tue Dec 13, 2011 7:51 am
I remember one of the early kart mags had an article on them. Should be able to get a timing spec there. Might want to back it off a degree or two just to be safe.
Scott Grundfor
1960 go kart 400c
1960 percival
Post by Scott Grundfor » Tue Dec 13, 2011 4:23 pm
Thanks Rob,
Post by Tom Smith » Tue Dec 13, 2011 7:06 pm
Is that the Macio center mounted directly behind the seat? If so that could be more of the problem that ignition timing. Not enough cylinder cooling.
Scott Grundfor
1960 go kart 400c
1960 percival
Post by Scott Grundfor » Tue Dec 13, 2011 9:31 pm
Yes, The Maico is mounted behind the seat. It was about 75 degrees the day I stuck the piston. Probably would be a good idea to have some sort of ducting? I'm not sure but it may have originally been run on Alcohol. It was put away in the early 1960's. When I got it there were twin flatback carbs instead of the 22mm Bing. I put the Bing back on.
