Airheart Brake Bleeding
Re: Airheart Brake Bleeding
Post by ted johnson » Fri Apr 09, 2021 8:09 pm
Rob, definitely NOT O rings, but also not standard brake cylinder cups. I don't know if Pruit got around to machining his old pistons to accept the available cups. I figured he'd send me a sketch so I could make a CAD model and machining drawing, but so far he hasn't had time. There's no reason w couldn't make solid pistons. A bump on one end for the actuating arm and two standard O ring grooves and it would work perfect. Ted
