I haven't done any work on the Airheart disc brakes until now but I ran into a problem after installing new pads- with the 'anvil' pad in place, theres not enough clearance left to install the main caliper. Everything locks up, even though the caliper piston is fully compressed. The anvil pad is pretty thick, does it need to be ground down, or do I need to make a spacer between the anvil and main caliper? Is one commercially available? I'm using 1.5" series '150' pads, bought from Comet Kart sales. HELP!!!! THX, Matt Azzara
matt azzara
Private messageE-mail
airheart brake relining
matt azzara
- Vintage Karting items owned: Robron A-Bone- WB 820
Dart GP
Go Kart 1200 - User Agreement: Yes
Re: airheart brake relining
They make shims.
- Rick Chapman
- Vintage Karting items owned: 1961 Bantam B-Bomb, 77' Hornet Enduro, 79' Hornet Wishbone Sprint, 1962 Blitz F-1000
Although most people will tell you to shim, I ground mine down on a disk grinder. A little off both the piston side and the fixed side. If I were racing the kart, I suppose I would shim.. Just a thought...
buy the steel spacers, lots of them, depending on the pads and your brake disk thickness, you could end up using up to 5 Airheart spacers (that is what I have on a kart I just put brakeman pads in, they are a thicker pad for longer life).
You will find the hard to find Airheart p/n on the brake bracket drawing notes, pick a drawing at the bottom of this page:
http://rearenginekarts.com/h_a%20brake%20project.htm
then call up Tol-O-Matic, cause you won't find that part online: http://www.airheart-brakes.com/
