R-1 Brake hub rotor problem has been solved
Post by Mark Loraine » Sat May 02, 2026 4:48 pm
New Billet CNC R-1 McCulloch brake hub rotor
Not mine and not related
Title "New , Quality Kart Disc Brake Hub for Vintage 1961 and 1962 McCulloch Karts"
https://www.ebay.com/itm/306913233301?_ ... R_ydmaa9Zw
Not sure if not having a 1 inch steel sleeve is going to be an issue or not.
Re: R-1 Brake hub rotor problem has been solved
Post by REAR » Mon May 11, 2026 6:39 pm
What was the original construction technique, did it have a sleeve ? Almost would think this is a failure waiting to happen.
Post by Mark Loraine » Tue May 12, 2026 6:52 pm
REAR wrote: ↑
I believe it was a cast in steel boss, like they do for the McCulloch rear wheels.......maybe a 1/4" keystock made of brass or aluminum could stand in for that steel insert?
