820 needle bearings vs cage bearings
travis stevens
Vintage Karting items owned: 1971 rupp d 301 , 1962 rupp grand prix, rupp lancer, rupp dart a-bone
Post by travis stevens » Tue Sep 29, 2015 9:13 pm
hello everyone im currently in the process of building a modified 820 and would like to know if the (cage )rod bearings are good.... i have been told in the past that i want to use needle bearings but i can not find them anywhere... any info would be appreciated and also im going to be running an hr tillotson what should i set the timing at on this motor.... it will be gas for fuel thanks
Re: 820 needle bearings vs cage bearings
Post by ted johnson » Tue Sep 29, 2015 9:48 pm
Full compliment needles are better than caged. You just have to dig until you find some. Try Dave Bonbright at 707 938-8122, or Dave Fillman at Fillman Machining, david@fillmanmachining.com 610 310-7312. Louie Figone might be able to point you to some if neither of the "Daves" have them. louiemtb@aol.com TJ
travis stevens
Post by travis stevens » Wed Sep 30, 2015 11:18 am
Thank you sir
Post by REAR » Wed Sep 30, 2015 2:52 pm
Travis,
How about US Power direct
Post by ted johnson » Wed Sep 30, 2015 5:13 pm
I heard some talk that maybe the old style needles waxed together in a strip on a paper backing might be reintroduced. If that's the case, it'd be really worth applause. That setup is incredibly easy to install. you turn the block head end down, run the piston down in the bore so there's a little clearance between rod and crank and slide the strip of needles off the paper into the gap. Wrap the free end of the strip around the crankpin and install the cap. After torqueing, a quick heat with your Harbor Freight heat gun, a squirt of oil and you're finished. I hoard these NOS needles on a strip like gold! Ron Cubel had a few of them, and very kindly donated them to me. I'm saving them for the next Bonbright 610. TJ
Post by Dick Teal » Thu Oct 01, 2015 5:57 pm
You can buy the needle bearings direct from US Motor Power. Do not use the caged bearings.
The factory ordered the needles for vintage karters so we need to support them. They also ordered the single groove dual ring pistons for us.
