SEARS MODEL 300 GO KART
BOBBYMUHA
Vintage Karting items owned: POWER PRODUCTS, DART KART
Post by BOBBYMUHA » Wed Jun 19, 2013 9:27 am
DOES ANYONE HAVE A SEARS 300 GO KART THAT YOU COULD MEASURE THE O.D. OF THE AIR FILTER THAT GOES BEHIND THE SEAT. THE KART I PURCHASED HAS THE AIR FILTER ASSEMBLY MISSING.
THANKS BOBBY
Ron Reaves
Vintage Karting items owned: 65 GrandPrix/Mc92, A-Bone/Mc91, Rupp D300, Sears R300, Putt Nik, Panther X & Concept
Re: SEARS MODEL 300 GO KART
Post by Ron Reaves » Wed Jun 19, 2013 12:29 pm
Do you need the OD of the filter element or the outline of the sheet metal casing that mounts to the back of the seat that the auto filter element mounts into? I can provide tracings of the entire assembly if that's what you need. I was going to make a couple assemblies up but never got it done.
BOBBYMUHA
Post by BOBBYMUHA » Wed Jun 19, 2013 12:38 pm
HEY MAN YOUR JUST UP THE ROAD FROM ME I AM IN BRANDON MS. I HAVE GUY THAT WILL MAKE SOME JUST NEED ALL THE DIMENSIONS YOU HAVE. THANK
Ron Reaves
Post by Ron Reaves » Wed Jun 19, 2013 4:43 pm
Bobby, PM me your mailing address and I'll send you an actual size tracing of the seat back brackets. The filter measures 6.5 in. O.D. and 3.0 in. thick. It is a standard auto air filter but I don't know what brand or part number.
This info was sent to me by Phil Riley of Topeka, MS.
BOBBYMUHA
Post by BOBBYMUHA » Thu Jun 20, 2013 7:38 am
BOBBY MUHA
206 LANGFORD FARMS COVE
BRANDON, MS 39047
Ron Reaves
Post by Ron Reaves » Fri Jun 21, 2013 11:17 pm
Bobby, we do live only a few hours apart. There are few of us in this area so we need to talk. Email me at: Clearskies01@juno.com I keep my "stuff" down at New Albany, MS which is about 3 hrs from Brandon.
I mailed you the tracing of the filter housing this evening. You should get it the first of next week.
Later....Ron
BOBBYMUHA
Post by BOBBYMUHA » Tue Jun 25, 2013 12:28 pm
RON ,I GOT THE TRACING YESTERDAY FOR THE FILTER, WOULD YOU LIKE FOR ME TO HAVE YOU ONE MADE WHEN I FIND OUT THE COST?
THANKS BOBBY
Ron Reaves
Post by Ron Reaves » Wed Jun 26, 2013 6:33 pm
Yes, let me know cost. There is a collar that comes out from the hole at the center of the bracket. It should be wide enough to put a hose clamp on to hold the hose to the carb. Same on both sides for twin engines. The catalog offered the kart with the 4-cycle or an optional AH58 or two AH58s. Also, seems there was a lip around the outside diameter of the filter. I don't know for sure of the dimensions.
Post by Rob Voska » Wed Jun 26, 2013 10:10 pm
It was like a large filler neck on the old gas cans with the large hole in the center & smaller spout with a tiny spout. My guess 3-3-1/2".
