Unknown Tillotson HR carb
Post by Scott Kneisel » Thu Jun 07, 2012 5:29 pm
I have a Tilly HR184A and would like some info on it before I use it.
Same size and configuration as an HR181A but with a larger idle needle. It also doesn't have a dump nozzle, just a hole. Looks factory with no obvious mods.
Alky? Gas?
Anybody know anything about these?
Re: Unknown Tillotson HR carb
Post by Rob Voska » Thu Jun 07, 2012 6:15 pm
Hi Scott I got yoru email but have been busy. 184 replaced the 181. Might be a bigger bore like a Mikuni if I remember right. I'll email you hole sizes to see if it's an alky carb.
Don Carlson
Vintage Karting items owned: 1961 Dart A-Bone Roadrunner Single W820, 1974 Bug Scorpion Dual WB820's
Post by Don Carlson » Thu Jun 07, 2012 10:44 pm
Lots of Tilly carb specs here: http://www.gokartracingengines.com/cata ... carbs.html
Part # Venturi/Throttle/ Fuel Type
HR-181B 1.11 1.325 GAS
HR-190A 1.11 1.375 GAS
HR-191G 1.195 1.355 GAS
lynn haddock
Vintage Karting items owned: Over 100 Vintage karting engines
Post by lynn haddock » Fri Jun 08, 2012 5:11 pm
the 184 originally came on the Komet K55 and was a gasoline model.
Later it was also offered by Hartman Engineering in an Alky version.
You can see the drill patterns for the gasoline model in some of the earlier IKF and WKA technical manuals.
Post by Scott Kneisel » Sat Jun 09, 2012 8:13 pm
Thanks Rob for all the great drilling info.
Thanks Lynn for the history of the 184, I was wondering what it was made for.
The carb is in the Gas form right now but it could be easily converted.
