SEAT REPAIR ADVISE
Sterling Brundick
Vintage Karting items owned: 1961 Mantis
1982 - 83 Margay Bandito
Margay Panther
SEAT REPAIR ADVISE
Post by Sterling Brundick » Wed Apr 18, 2012 8:32 pm
Assuming I can post the picture showing the issue, I would like some advise on the best way to repair the damage. Well, it did post. The kart frame is a 1961 Mantis that I am restoring for my kids. Should I remove the old backing and replace it completely?
Sterling
(177.87 KiB) Downloaded 332 times
steve miller
Vintage Karting items owned: simplex,rupps,fox,putt nik,go kart 1600,alley cat ,hellcat,mcculloch,hornett,moss..
Re: SEAT REPAIR ADVISE
Post by steve miller » Wed Apr 18, 2012 10:20 pm
sterling .. floor pan dont look bad ....i say timewise it will take you as long or longer to try patch it than it would take to replace .. cut right in the upper center of the break ..then when you mark out your tin for your new seat back make it 3/8th inch longer and break it 30 degreess or so and adjust till it matches floor pan tuck it under floor pan and it very hard to notice .. its only a suggestion .. and its the way i do it ..
Sterling Brundick
Margay Panther
Post by Sterling Brundick » Thu Apr 19, 2012 12:33 pm
Thank you Steve.
