SAE Fuel Tank
Don Tomich
Vintage Karting items owned: 81 Pro 100/BM Reed
72 ANS Dominator/Parilla TG14
DAP T74
1965 SAE Repro
SAE Fuel Tank
Post by Don Tomich » Wed Mar 07, 2012 1:02 am
Need help in mounting a half round seat back tank to the steering column support of an SAE kart.
From photos it appears the tanks are fixed by 2 bolts only through the steering column support.
Is this correct or are extra mounting points required that I can't see in photos.
Regards,
DonT
Re: SAE Fuel Tank
Post by Rob Voska » Wed Mar 07, 2012 8:15 am
Just 2 #10 bolts is all that hold them. Use some washers to spread the load.
Don Tomich
DAP T74
1965 SAE Repro
Re: SAE Fuel Tank
Post by Don Tomich » Thu Mar 08, 2012 5:47 am
Thanks Rob, that's the way it looked to me but I imagined that it wouldn't take long for the mounting rim on the tank to crack.
Don
Re: SAE Fuel Tank
Post by Rob Voska » Mon Mar 12, 2012 1:13 pm
I have two tanks on mine & added a spacer & another bolt on the bottom to stop flexing.
When mounting a single tank on an SAE they pushed the tank up between the steering hoop slightly denting the sides of the bubble on both sides & bolting thru the fange. Must have helped a little bit.
