mac7
kyle moody
Vintage Karting items owned: Rathman Xterminator
mac7
Post by kyle moody » Wed Nov 17, 2010 6:58 pm
Hi guys could u give me any info on the mac 7 engine is it a good engine to have do they run good stuff like that thanks Kyle
Re: mac7
Post by ted johnson » Wed Nov 17, 2010 9:38 pm
Kyle, the Mc7 (and Mc30) are McCulloch's first 100cc engines. They still used the "third port" to charge the crankcase, and they were the first Macs with the large crankcase opening on the manifold side. The Mac 8's, 9's, and 40's are all similar, except that the '40 had dual carbs and a single exhaust port. Of course, the 7, 8 and 9 are considered "standard" series engines, had the small air shrouds and the needle/roller bearing on the PTO side, along with a different ignition point setup and longer ignition coil mounting posts. The 30 and 40 had ball bearings on both ends of the crank and sold for a higher cost. There's more, but you get the idea. These are all great performing "classic" McCullochs, and will give you a good ride. ;) Ted
kyle moody
Re: mac7
Post by kyle moody » Wed Nov 17, 2010 11:02 pm
Thanks for the info Ted
