what kart is it (tubes are aluminum )
Post by david a luciani » Sun Sep 26, 2010 12:13 pm
this is posted on the vintage site owner can't post here yet so i am helping him out
what is it ?
i'm pretty sure i've seen pix in the mags but don't remember where.
(29.95 KiB) Downloaded 916 times
(41.75 KiB) Downloaded 916 times
Re: what kart is it (tubes are aluminum )
Post by Rob Voska » Sun Sep 26, 2010 11:31 pm
Capital Kart I think.
steve miller
Vintage Karting items owned: simplex,rupps,fox,putt nik,go kart 1600,alley cat ,hellcat,mcculloch,hornett,moss..
Post by steve miller » Mon Sep 27, 2010 6:22 pm
does anyone think its a titan .??
Michael Allman
Vintage Karting items owned: ,1980 corvette with rupp running gear and aluminum frame go kart
Post by Michael Allman » Tue Sep 28, 2010 9:34 pm
this kart has scrub brakes on the back ,does that date it.
Post by ted johnson » Wed Sep 29, 2010 8:36 am
It's definitely not a production Titan. They were twin tube full length, and totally different configuration. Looks home built.
Michael Allman
Post by Michael Allman » Wed Sep 29, 2010 9:58 pm
Not homemade had rack and pinion ,bolt on spindle mounts, name tag was on right side of steering support but they lost it over the years . They [the prev. owners said it had a Indy body on it, can't find were it was mounted .They removed bolt on spindles and rack to put on a racing lawn mower
(75.66 KiB) Not downloaded yet
Mike Reller
Vintage Karting items owned: 1961 Bantam, 1962 McCulloch
Post by Mike Reller » Sun Oct 03, 2010 11:29 am
It does seem stange that somebody would use so much aluminum in a frame, then use those big pillow block bearings for the rear axle. I also cant see any advantage to having a front axle set up that may cause, "on the fly" caster adjustments. I've known guys who had tig welders who were great welders, but lacking in the fabrication department. Does anyone else think that a little more research may be in order before doing anything rash?
Also, it was mentioned on another site that there was a dealer who could provide lots of parts. Well, American Power Sports carries all of the Azusa stuff, and a whole lot more. Plus,they support this site. The prices are better too.
Michael Allman
Post by Michael Allman » Sun Oct 03, 2010 2:26 pm
Downloaded American Power Sports cat. The spindles was used on a racing lawnmover. One bolt to hold on but they had a pin in the face where you could rotate the spindle . The axle is 37 " wide with a 3in cut back on each side This frame was painted black and then red on top of that. Do you think someone was cheating or what .The rack and spindles were put on a racing lawnmower.
Michael Allman
Post by Michael Allman » Tue Oct 05, 2010 9:58 pm
Steering wheel and back hub
(78.22 KiB) Not downloaded yet
Michael Allman
Post by Michael Allman » Thu Oct 14, 2010 9:04 pm
Does anybody have a clue of who made this cart.
