Fellas i have a Wiseco .060 o/s piston for one of my rebored 101's and the pin length is 1.325 would any of you happy campers have one and if so i could pay you via paypal for the pin and postage to Australia.
Here's the diameter of the pin required .565 x 1.325 using my dial caliphers.
Note this piston uses a closed needle cage on the exhaust end.
McBob.
Piston wrist pin to suit Wiseco piston
Re: Piston wrist pin to suit Wiseco piston
9/16" pin, some of the big saws and late saws used those pins as well as the kart motors listed. Super Pro 105 and Super Pro 125Cs use a full length 9/16" pin that you could always grind shorter, pn89204. Same rod and pin the chrome bore kart motors used. I think the 797 and Super 797 also used them which is basically what an
Mc- 101 is. Contact Dewey or Terry
