Rupp Uni-mount Measurement:
Merv Cary
Vintage Karting items owned: Mid 60's Rupp Chapparral Enduro Kart. (2 MC 91A's)
Post by Merv Cary » Tue Jan 19, 2010 11:36 am
Can someone tell me the length of the tube that the axle goes thru with the bearings in it and a couple more . I am going to attempt to make my own mounts as this are pretty expensive. I numbered the mearurement that I need so it will be easy to list. OOP'S, I forgot to list the side plate mounting bolt locations.
Merv"
Terry Schmitz
Vintage Karting items owned: 63 Brand X, 64 Fox Box ,71 BucketBug ,66 LANCER,63 GP, Rupp F35,66 CHAPERRAL SPRINT/ENDURO
Re: Rupp Uni-mount Measurement:
Post by Terry Schmitz » Tue Jan 19, 2010 2:26 pm
Merv, contact mike Branham with Derby City Karts in Louisville,KY he has made these 502-239-0080 he can probably make them for you. Terry
Merv Cary
Post by Merv Cary » Tue Jan 19, 2010 3:42 pm
Terry,
Thanks for the info.
"Merv"
Tom Luttenbacher
Vintage Karting items owned: Dart A Bone, Neal, LeeKart, Lancer, GoKart 800's, Simplex, Blitz.
Post by Tom Luttenbacher » Tue Jan 19, 2010 9:46 pm
Merv, I'll try to post again, the first failed I see. If I were building the mount this is what I would do; #1 see #4, #2, see #6, #3, 4 inches?, #4 measure the mount on a Dart Kart where the swing mount fastens, it's on the frame cross tube, #5 1/4 minimum possibly 3/8ths for the heavy then go to 3/16ths, #6, Get an engine side plate that Vince Hughes sells to locate bolts holes and also give you clear width for #3, #7, 1/2 inch. Hope that helps. Tom
Merv Cary
Post by Merv Cary » Wed Jan 20, 2010 4:51 pm
Hi Tom,
Thanks for the numbers. I will Get these measured out and see what I can come up with.
"Merv"
