looking for way to adapt HR carb to west bend 820
Terry Schmitz
Vintage Karting items owned: 63 Brand X, 64 Fox Box ,71 BucketBug ,66 LANCER,63 GP, Rupp F35,66 CHAPERRAL SPRINT/ENDURO
Post by Terry Schmitz » Sun Feb 15, 2009 11:19 am
i'm wanting to put a HR on my 820 . what are my options? terry
Re: looking for way to adapt HR carb to west bend 820
Post by Rob Voska » Sun Feb 15, 2009 1:15 pm
There were a few cast manifolds for WB / HR setup's but they are very hard to come by.
GEM V12 or V6 stuffer would also be other options.
Gordon Duax
Vintage Karting items owned: Lots!
Post by Gordon Duax » Thu Feb 26, 2009 5:31 am
If you notice, the middle 2 bolts on the 820 sidecover
are the exact same spacing as an HR carb.
You can take a Mac manifold, and cut the reed block part off,
then drill the holes strait through.
By using longer studs, it will mount right over the 820 side cover.
It is best to use an after market side cover, like a Reed Eng., or GEM.
And it will need to be machined flat where the Mac manifold chunk sits.
(or any voids or low spots filled with epoxy, and then cut flat)
You then cut a hole through the side cover, that matches the Mac manifold opening.
Make yourself a gasket to go between them,
and you now have a cheap HR / big Mac carb manifold.
Of coursr, if you want to use an HR on the Mac reeds,
you will need to plug the 4 pulse holes, and drill one matching the Tillotson pattern.
I have done several of these for people, and it works out real slick.
Carl Haydt
Vintage Karting items owned: just enough to keep me racing
Post by Carl Haydt » Thu Feb 26, 2009 6:36 pm
Terry,Here's what gordon is talking about-works great for the big bore Mac carbs too! Carl
(164.7 KiB) Downloaded 82 times
(156.4 KiB) Downloaded 67 times
Post by ted johnson » Thu Feb 26, 2009 8:32 pm
Terry, Carl and Gordon have a great idea! Of course, this will leave you with 1/4" studs - fine for the big Mac carb, but the HR and the Mikuni have holes for 5/16" studs. A quick cure: McMaster Carr has 1/4" I.D X 5/16" O.D. X 1/4" long bushings for cheap. Part No. 6391K126. http://www.mcmaster.com. I use them as spacers - they work great. Good for adapting a HR or Mikuni to your Mac big manifold, too. ;) Ted
Tom Luttenbacher
Vintage Karting items owned: Dart A Bone, Neal, LeeKart, Lancer, GoKart 800's, Simplex, Blitz.
Post by Tom Luttenbacher » Fri Feb 27, 2009 12:23 am
Hey guys thanks for the tips an pics. Here's what I do with the bigger stud holes in the Mikuni; find in your old gas line collection a piece of the hardened 1/4 inch line, cut two pieces the thickness of the carb flange, use pliers and carefully screw the hose down the stud, you can do this after gasket is in place, install the carb, it will go on tightly so be ready to use a little effort or slippery slide, go jo, some kind of lube, tighten nuts and go have fun. Tom
