spindles and hangers
We're designing a fresh kart. We're looking for rear steer spindles, 7 to 9 degrees kingpin inclination. We'll use 12 degrees of caster. ) to 1 degree negative camber. We need the chassis hangers for these. Need quality parts, 5/8" axles, long enough for Series I, 5" Go Power wheels, and drilled for cotters. Coyote makes them, but they are a bit pricey. Can't lay out the front axle tube until I know what we have to use. Thanks a ton. Ted Johnson
