WTB Recoil for West Bend 580
- Vintage Karting items owned: Rupp Chaparral, Neal kart, Several Mac engines
I need a recoil for a West Bend 580. I know there are at least two different styles. I need the one with the smaller diameter mounting points. Spacing across is 4-5/8" from hole to hole. Picture is my engine. Thank you.
- West Bend 580.jpg (75.17 KiB) Viewed 7891 times
Last edited by gordy mccaffer on Fri Jun 12, 2020 3:08 pm, edited 4 times in total.
- Vintage Karting items owned: ProX 77,McC R1,Bug Stinger Dual.
Re: WTB Recoil for West Bend 580
whats the rotation looking at your picture?
Pretty sure it's clockwise. That's assuming, when mounted on a kart, that the cylinder would be in the rear with exhaust facing rearwards. Here's a picture of the other side.
I'm starting to get the feeling that a recoil for this engine may be hard to find.
Look at chain saws & Tecumseh engines. Lots of them around but a lot of variations also. 2 bolt patterns and at least 2 depths of cups. Some cups are smooth inside & some have saw teeth.
Thanks Rob. I guess my other option, if I put this engine on a kart, is to install a starter pulley and use the starter cart.
- Vintage Karting items owned: Simplex MKII
If you're still looking for a recoil I may be able to help you. I tried sending you a PM but there was a problem, you can reach me at mjarosik@ptd.net.
E-mail sent. Thanks.Michael Jarosik wrote: ↑Sun Jun 21, 2020 11:23 amIf you're still looking for a recoil I may be able to help you. I tried sending you a PM but there was a problem, you can reach me at mjarosik@ptd.net.
