1960s Simplex
- Vintage Karting items owned: 1960s simplex
1960s Simplex
Recently bought vintage kart, was told it is a 1960s simplex. There are no identifying markers to validate this. It has a live axle in a housing with dual rear drum brakes, dual motor mounts. The steering column brace is shaped like two candy canes that meet at the steering wheel. All mechanical brake and gas mechanisms. Original color orange. Has original Good Year slicks. Rear drum brakes have roll brake linings. No motor or gas tank. steering linkage goes under kart ,has low profile seat Any thoughts?
- Ronald Cubel
- Vintage Karting items owned: Xterminator Kart
Rathmann Kart
Exterminator Kart - Contact:
Re: 1960s Simplex
Sounds like a Putt Nik need picture.....ron
Re: 1960s Simplex
Please use your real first and last name when registering. If your posts have been deleted you now know why. Please edit your profile. Thank You
FYI - you can change your user name after joining. Go to upper right corner, and click on USER CONTROL PANEL, pick PROFILE from menu on the left, then pick sub menu EDIT ACCOUNT SETTINGS. Then replace your user name with your real name.
