Can Someone I.D. This Kart?
Timothy Klatte
Vintage Karting items owned: Simplex Challenger Mk4
Re: Can Someone I.D. This Kart?
Post by Timothy Klatte » Sat May 18, 2019 8:29 am
I've never heard of this brand....but they sure look alike!!! I think it's the front axle design that sells me.....
Post by ted johnson » Sat May 18, 2019 11:12 am
Timothy, the Standun karts generally had a much more "rounded" seatback than your pix show, and the steering hoop on Standun had a sharper bend. Standuns had a flat stock steering wheel center bar whereas yours is round bar. If you blow up the pic of the front view of your kart, it is obvious that the front axle has been much modified. There are some gobby welds on both sides of the lower steering shaft support. It isn't easy to bend square tubing. Probably the original axle got damaged on one or both outer ends, and it was easier to scab on straight pieces of tubing than it would've been to bend the stuff. It'd be good to see how the main rails got "teed" into the revised front axle. The rails are higher at the joint than the axle is. It's been too long since I saw a Standun in person, so I don't remember the brake setup. TJ
Timothy Klatte
Post by Timothy Klatte » Sat May 18, 2019 1:48 pm
Thanks Ted!!!
Post by Rob Voska » Sun May 19, 2019 8:16 am
The zip kart steering wheel is correct but from the picture I can't tell if it's square tube or not.
What part of the country is it in?
Timothy Klatte
Post by Timothy Klatte » Sun May 19, 2019 9:04 am
Near Pittsburgh, Pa.
Tom Luttenbacher
Vintage Karting items owned: Dart A Bone, Neal, LeeKart, Lancer, GoKart 800's, Simplex, Blitz.
Post by Tom Luttenbacher » Mon May 20, 2019 3:28 pm
The Standun Rocket has an entirely different front axle that the "what is it" kart but I have to agree they have the late 50's build style.
Post by Rob Voska » Mon May 20, 2019 6:19 pm
Odds are then it's a Zip kart from B&H Machining Inc. Somerset PA.
